Drawing - dimension decimal separator
Message 1 of 8
Hello!
I was wondering if it is possible to change the decimal point display in drawings - from point to comma?
While adjusting this option in preferences, it changes it in the preferences display and in sketches - but not also in drawings which would be much needed.
Thanks in advance for your help!
Kind regards,
Denise
Replies (7)
Message 2 of 8
andrew.de.leon
Hi @Anonymous,
Thanks for reaching out. Unfortunately drawings have aligned with the ISO and ASME drafting standards and as a result use a decimal point. So although sketches will display a comma, the change does not modify drawings. Can I ask why you need a comma? Are you trying to match an existing company drafting or construction standard?
Andrew
15" Retina MacBook Pro (Late 2013), OS X El Capitan (10.11.4), in Sydney Australia
Andrew de Leon
Experience Designer - Fusion 360
MacBook Pro (16-inch, 2019), OSX 10.15.7, in Sydney, Australia
Message 3 of 8
Thanks for fast feedback @andrew.de.leon !!
I'm trying to follow the European Construction Standard which we're using at our University.
To be more specific, at the University of Rijeka, Faculty of Engineering.
I would be extremely grateful if there would be an update for this option!
Thank you in advance!
Best regards,
Denise
Message 4 of 8
andrew.de.leon
No problems Denise, and thanks for providing more details about your request.
At this stage, Fusion 360 Drawings has aligned with the ISO and ASME drafting standards for manufacturing. So we don't do a very good job of supporting construction or building standards. I will add you request to our roadmap and in the meantime, it would be great if you could add your request to the idea station so other users can vote on it.
Andrew
Andrew de Leon
Message 5 of 8
Here in Argentina we also use comma for decimals following IRAM.
It would be really helpfull for all University Students of Design and Engineering to have that add on the drawings in order to not change every dimension by hand. Slows up the process a lot.
If you find yourself in our shoes please vote here: https://forums.autodesk.com/t5/fusion-360-ideastation-archived/comma-as-decimal
thank you!
Message 6 of 8
GutenBar
The Brazilian Association of Technical Standards (ABNT) also uses the comma as decimal symbol.
Message 7 of 8
lawrenceYQS8Z
Hi Andrew (/ Autodesk Support),
I'm not sure I agree with you that ISO specifies the dot as a decimal marker rather than the comma. My understanding is that ISO 129 (used in UK, France and Germany at least, and also called out in BS 8888 which is a very commonly used and comprehensive draughting standard), requires the comma to be used as the decimal marker and spaces between thousands so e.g. 20,001.34 becomes 20 001.34 (see attached excerpt of BS 8888).
Could this option be added for the drawings please in Fusion 360? Hopefully it is quite a simple change?
Lawrence
Message 8 of 8
xhornaceks
Community Visitor
Community Visitor
Hello, has anybody any solution to this problem? I'm facing it still in 2023.
Thanks for replies.
