- Mute
- Permalink
- Report
When longitudinal cut is made view of part is shaded.
It could be dataset specific issue. Please share the dataset, or you can share the link of dataset by email. Thanks
Please share the link of file with us, and allow downloading. Thanks
Thanks for sharing the dataset. Checking the details of the 3D design, body 10 and 11 are bad body in UKP210-J7. Showing as the snapshot, the solid body is open and the face is too thin. It is not a quailfied solid body. Please rebuild these bodies in 3D design. Is this body created in Fusion, or imported from other file format ?
In drawing, you can hide the bad bodies to get the correct section view, showing as the second snapshot. Hope it works for you.
Fanstastic. Thanks a lot.
Never come across such problem.
This bearing housing I don't remember where was download, but 99% downloads are made through "Insert manufacturer part"
