I want ask whether it is possible to use Lump mass method to do force analysis simulation, this is for my client payload model. My client suggest to create a lump mass (0D element) to represent payload( due it be complicated) and then link that element to platform attachment points via rigid links/connections. They say that it will make simulation work more easier and faster.
However, I don't know whether this is even a viable method to do simulation with in fusion 360 because i have never done it before . So i want to check if this is method is even possible and is there such thing as exporting model in lump mass format.
Solved by henderh. Go to Solution.
Solved by CGBenner. Go to Solution.
@shantidass
Hello and welcome to the forum!
@henderh do you have any insights on this?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi @shantidass,
I believe a Remote Force load can fulfill the requirement. It can be used to represent a load from complex geometry, or geometry that isn't included in the model. It uses rigid links to transfer the load (force and implicit moment) to the selected faces of the modeled geometry.
If you're only interested in the effects of weight from the complex geometry or geometry not included in the model, the analysis can be simplified by representing it using a point mass.
Neither of these methods require creating Rigid Body Connectors manually. The Rigid Body Connectors are added automatically in a Remote Force. In a Point Mass, the loads from the weight are applied directly to the selected faces.
@henderh Hello, just wondering if you saw this latest response from @shantidass ?
Chris Benner
Hi @shantidass,
Please let us know if you have any questions about using the suggested approaches.
Best regards,
