drawing CIRCLE when i only know the chord length and number of chords
dieselguy65
Message 1 of 8
dieselguy65
i am trying to draw a circle,  based on only knowing the chord length of 0.625" and the fact it has 48 equal chords.
I do not know the radius of the circle.
i have a formula to figure it out.
but i thought it would be  simple thing to draw with the information i have been given.
2 days of failed attempts has me asking if its possible, without first doing the math manually to figure out the radius of the circle.
and if it is , could someone lead me in the right direction to get started?
thanks
Replies (7)
Message 2 of 8
HughesTooling
does this work?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
dieselguy65
those are the numbers i got when i run the formula on paper.
but i am not sure how to get ti transferred to the computer.
other than using the paper results, to draw a circle 7.556" in diameter and placing the chords on it.
but i was trying to do it, knowing the chord length, and number of them, that also tells me the angle between them..
i was drawing two chords, of the correct length, with the angle, and trying to pattern that.
but without having the circle center defined it wasnt working
i can draw a line, from the chord ends, to a common point, that would be the center, forming  a triangle with angles of 86.25, 86.25 and 7.5 degrees, with the base being the chord length.
if that even makes sense.
i was hoping for a way for fusion to find me the center of it.
my other way was to make a circumscribed 48 side polygon, after i calculated the radius
Message 4 of 8
wersy
Why don't you take the center first.
Draw two lines of equal length from the center at an angle of 7.5°.
Close the two lines at the end with a line to a triangle.
Measure this line with length of 0.625
This automatically results in the radius.
Message 5 of 8
davebYYPCU
With just Your particulars,
48 sided polygon, dimension a leg, orientate as desired.
Might help....
Message 6 of 8
dieselguy65
i can do that. but was looking for a way with only the info i was given. without having to find any other angles or lengths.
Message 7 of 8
dieselguy65
that works great. if only i could have been able to see the tooltip. i would have found it i am sure
i was trying the inscribed and circumscribed style.
never used the one below it.
thanks
Might help....
Message 8 of 8
chrisplyler
Based only on info given in your first post...
