Drawing, change angle of exploded view
hato54
Message 1 of 9
hato54
I need to tilt the view, how could I do that?
I tried to change the view in the "animate mode" but the drawings is always the same view.
/Håkan
Replies (8)
Message 2 of 9
krithika.sundararajan
Hi hato54,
A Rotate transformation in the Animation workspace should work for the drawing view as well (see screencast for reference: http://autode.sk/1UFoVal).
If you would like this to happen for drawings created from the Model workspace, you could create custom named views to achieve a rotated view (apart from rotating the model itself).
Rotating views in the drawings is on our roadmap and should be available later this year. Until then, you could use the above methods. Please let us know if this works for you.
Krithika
Message 3 of 9
hato54
Thank You @krithika.sundararajan , nice!
/Håkan
Message 4 of 9
hato54
For Your info @krithika.sundararajan
When I update some components the drawing will be corrupt.
Then I a make a new drawing it works ok.
/Håkan
Message 5 of 9
Hi Håkan,
Sorry to hear you're facing issues with updating your existing drawing - that shouldn't happen. I gave this a quick try and it worked for me.
Could you share some more information on what you are seeing (dimensions lose associativity with the view / Error dialog / ...)? A screenshot would be helpful. We'll look into the issue as soon as possible.
Krithika
Message 6 of 9
hato54
hi
As You see above it's only the graphic drawing that is corrupted.
No errors or message.
/Håkan
Message 7 of 9
Hi hato54,
Thanks for reporting this. I'm still having difficulties reproducing this. If this happens again, it would be of great help to us if you could share your file with us.
Please inform us if you encounter this again.
Krithika
Message 8 of 9
hato54
Hi @krithika.sundararajan
I still have that problem even after restarting the computer.
Unfortunate can I not send these files because the belong to my customer.
I have 10 parts and one assembly, then a make a animation of the assembly file and make a exploded drawing.
The drawing is ok and also the part list.
Then if I have to change one of the parts I do that and update the assembly file, save it and then update the drawing file.
The parts will update ok but I got some errors in the exploded drawing. Some part are moved and not the same angle as before.
Then if I make a complete new drawing from the assembly file everything is ok. It seems to be something wrong using the update function.
Be aware of that I used a rotate and transform in the "animation mode" before a made the drawing.
Could the be the problem?
I have to test this
/Håkan
Message 9 of 9
hato54
@krithika.sundararajan Now I made some tests and I can't repeat the errors.
I'll come back if I will get the error again.
/Håkan
