drawing airfoils
drawing airfoils
drawing airfoils
I'm trying to find a way to import airfoils into Fusion. I tried reading in csv files to import splines, but this created a lot of problems as there are hundreds of xy-coordinates. I then tried drawing the airfoil in another program, and then importing an SVG file into Fusion. I projected the imported graphic onto a component, but there were problems with push/pull as I tried to remove sections from the airfoil.
Can anyone suggest the best way to import these kind of shapes.
Steve Garlick
Beyondforce
Hi @Anonymous,
Have you tried this:
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1569210467479959341&appLang=en&os=Win64
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Unfortunately, I don’t need a NACA airfoil, I need an AG airfoil. I can generate a csv file of the coordinates, or an SVG graphics file.
Thanks anyway,
Steve
Beyondforce
If you create a screencast, I'll be able to see where the problem is.
Ben Korez
| YouTube
Beyondforce
I this will help you.
Ben Korez
| YouTube
TrippyLighting
It might still be beneficial for you to install that plugin and see how the outpiut is
