draftsight title block into fusion 360
Hi ,
ive created a title block in draftsight.I have Defined attributes and purged the document.ive tried importing into fusion with no success. ive watched endless amounts of youtube videos and nothing is working.Is using draftsight an issue ?
cmiller66
Hi rosshall93,
I'm assuming you're getting the unsupported objects message when you try to insert this dwg into your Fusion drawing.  Is the geometry for the titleblock in model space?  Is it individual entities (this is required) or contained in a block?  Can you attach or send me (christopher.miller@autodesk.com) the dwg so I can take a look?
Chris
Hi Chris , thanks for the quick reply.
ive now managed to get the title block into the drawing but the attributes are not working.
As requested see attached.
cmiller66
Hi rosshall93,
When I opened your drawing in AutoCAD and checked the attributes they were set to "Constant."  I turned that off and now when I insert the titleblock in a Fusion drawing and double-click it, I get the expected dialog with the fields to change the values.
We don't currently auto-populate attributes in titleblocks inserted from a DWG, but are working on a block editor where you will be able to edit your block geometry as well as add some of the more common attributes like scale, create date, etc. and these will auto-populate when used in your drawing.
Please let me know if this edited block works for you.
Chris
Thanks Chris , i would never have thought to do that !
