Importing Assemblies and Maintaining Association with Individual Parts
I have searched the forums for an answer to the below question but have not found it:
I have been working in ProE/Creo for the past decade and for personal use have started using Fusion 360. I have done considerable design work I would like to start migrating over to Fusion 360 that is my own; however, importing into Fusion 360 does not function as I would expect (i.e., the same as ProE does).
When I import a step file into ProE, it creates the assemblies and it also creates the parts with their association to the assembly. That way, if I open the individual part and modify it, it is modified in the assembly.
When I import a native ProE assembly or STP file into Fusion 360, I get the choice of importing the assembly or the individual parts. If I import the assembly, it creates the assembly, but not the individual parts (i.e., they are not in my data panel) and it appears I cannot open the individual parts from the assembly without doing a save copy. After doing the save copy, you lose the association with the assembly but it is then available in the data panel.
Am I missing something here?
I want to be able to import the assembly and have the parts available in the data panel so I can open them, modify them, and see the update in the assembly after I open it.
Thank you,
Graham
