How to place edge of component against a face
oaklander
Message 1 of 14
oaklander
How can I make something similar to the assembly in the picture? The two joints on the left are easy but how do I make the one on the right? I have a Solidworks background and there I would just place the edge coincident with the face.
That's not possible in Fusion 360 but I think that I could enable contact and turn the angled plate against the horizontal plate and after that create a rigid group containing the horizontal and angled plate. Is there a better way to do it?
Replies (13)
Message 2 of 14
TrippyLighting
It takes less than a minute to do that stuff in your image in Fusion 360, but I am assuming you presented a simplified case.
Perhaps explain what you really want to model/design so we can provide you with better help.
Usually narrow questions yield only narrow answers and alternative solution are not provided.
Message 3 of 14
oaklander
The picture is not perfect, but I can't post a picture of the actual model.
But think that the picture is enough. All I want is to place the component so that its edge is on the face of another component.
Message 4 of 14
TrippyLighting
Easy as pie. See model attached.
Message 5 of 14
chrisplyler
Triiiiiiiiiiiiippy...
Suppose you had three Components brought in from separate files. How could you JOINT them into that position? Can you make an edge Planer to a plane? No.
Like this:
Rigid joint holding the two perpendicular bits together.
Revolve joint holding the third bit to the top.
Pin-Slot joint lines up the edge at the bottom.
Message 6 of 14
chrisplyler
And if you make the perpendicular joint a revolve instead of a rigid, then you can do this:
Message 7 of 14
TrippyLighting
@chrisplyler ROTFLMAO! Sure, but would that not be an assumption 😉
But seriously, why would you import three plates ?
Message 8 of 14
davebYYPCU
Can you make an edge Planer to a plane? No.  Yes you can.
Message 9 of 14
chrisplyler
@davebYYPCU  With a Joint? I'm unable to do so.
Message 10 of 14
chrisplyler
@TrippyLighting  I just thought the poster didn't really specify, and so to cover the possibilities, he might want to see how to have completely unrelated Components be Jointed into that position/behavior also.
I often make Components right in the master assembly file of course, but I want them to be fully self contained if possible, such that I could save them out separately if I ever wanted to. So I want unique sketches belonging to each Component that don't have any dependencies outside of that Component.
And besides...your solution didn't light up! Have you no honor, sir?
Message 11 of 14
davebYYPCU
Not so, you do it with every Joint, that utilises a vertex.
 (I am not including As built Joints)
Taking the triangle plates example,
Every edge is planar to a face, therefore a Joint created at any vertex, is then capable of being offset and or rotated to the desired position.  Joint's Move triad has 6 degrees of freedom in the creation routine.
Would need a screencast demonstrating the problem for a more specific answer.
Might help.....
Message 12 of 14
chrisplyler
@davebYYPCU  I definitely want to see that Screencast.
I am unable to create a Planar Joint between the two components that draws the edge of the "hypotenuse" Component down onto the face of the bottom Component in the orientation given previously.
Pin-Slot? Bingo. Planar? No joy.
Message 13 of 14
davebYYPCU
Planar, - Planar Joint, wasn't what I was thinking,
This is what I was thinking, but in making this vid, what I was thinking, doesn't work in all cases.
Message 14 of 14
chrisplyler
Right. Technically, a Revolve can bring an edge planar to a face.
But I had already used a Revolve to set the upper position of the triangle (as shown previously). Needed another joint to suck the other edge down to the bottom face. Can't do it with a Planar. That's the context in which I said you can't make an edge Planar to a face. I meant the joint type. Sorry for the confusion.
