Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Draft angle bug
2 REPLIES 2
HughesTooling
271 Views, 2 Replies
Draft angle bug
I've found an intermittent bug when modifying a sketch, the draft angle reverses for no reason. In the screen cast I'm using parameters to modify the sketch but modifying the dimensions in sketch mode has the same problem.
screencast
File: http://a360.co/1xYiXBJ
Mark
Mark Hughes
Owner, Hughes Tooling
2 REPLIES 2
Thanks for the file. I note if you do a compute all command from the modify drop down menu, that the draft angle flips. It may help (by locating a potential issue) to use the compute all before saving the design. I'm not suggesting you did anything wrong here. I'll log this with development for further review and reply back here whenever I have an update.
Nathan Chandler
Principal Specialist
Mike.Zhang
in reply to: innovatenate
We're using defect NO. FUS-16323 to track it.
Mike.Zhang
SQA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
