I've found an intermittent bug when modifying a sketch, the draft angle reverses for no reason. In the screen cast I'm using parameters to modify the sketch but modifying the dimensions in sketch mode has the same problem.
File: http://a360.co/1xYiXBJ
Mark
Mark Hughes
Owner, Hughes Tooling
Thanks for the file. I note if you do a compute all command from the modify drop down menu, that the draft angle flips. It may help (by locating a potential issue) to use the compute all before saving the design. I'm not suggesting you did anything wrong here. I'll log this with development for further review and reply back here whenever I have an update.
We're using defect NO. FUS-16323 to track it.
