Downloading a file for Fusion to read??
Hi-
I wish to download a file of a technical drawing to add to my Fusion design.
Which of the following should I download?
Big Thanx in advance.
G
Beyondforce
HI @Anonymous,
I think a .STEP file will be a good choice in many cases. Try it and see if you're happy with results. I usually do 🙂
Ben.
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous
I understand that you want to import to Fusion 360...
You can upload following file types to Fusion 360:
  • Alias files (*.wire)
  • AutoCAD DWG files(*.dwg)
  • Autodesk Fusion 360 files (*.f3d, *.f3z)
  • Autodesk Fusion 360 Drawing files (*.f2d)
  • Autodesk Fusion 360 Toolpath files (*.cam360)
  • Autodesk Inventor files (*.iam, *.ipt)
  • Catia V5 files (*.CATProduct, *.CATPart)
  • DXF files (*.dxf)
  • FBX files (*.fbx)
  • IGES files (*.iges, *.ige, *.igs)
  • NX files (*.prt)
  • OBJ files (*.obj)
  • Parasolid Binary files (*.x_b)
  • Parasolid Text files (*.x_t)
  • Pro/ENGINEER and Crea Parametric files (*.asm, *.prt)
  • Pro/ENGINEER Granite files (*.g)
  • Pro/ENGINEER Neutral files (*.neu)
  • Rhino files (*.3dm)
  • SAT/SMT files (*.sab, *.sat, *.smb, *.smt)
  • SolidWorks files (*.prt, *.asm, *.sldprt, *.sldasm)
  • STEP files (*.ste, *.step, *.stp)
  • STL files (*.stl)
  • SketchUp files (*.sku)
Here is Detail
Many thanks!
Mike.Grau
Hi @Anonymous,
I think I would go for AutoCAD *.dxf
That might works best if you want to review the drawing.
The company sent me a STEP file, and seeing as I had no choice I tried it.  And of course it works!
THANK YOU
hello
i have done a design for that design i need to convert into f3z file so i have converted in cloud download they  have send me the file to my mail as f3z file format i have downloaded it but i was not able to open and see it can any one please tell the solution for this.
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 community! Smiley Happy
You will be able to upload the file on the data panel. here is How to import or open a file in Autodesk Fusion 360.
For your reference, there are two types of archive files:
F3D - Archive file of a single design workspace
F3Z - Archive file of a distributed design (all x-ref designs included - multiple F3D files)
If you need more help, please let me know~
Have a great day!
Many thanks,
