Don't render lights
Don't render lights
guardian_de
Don't render lights
guardian_de
I'm struggling with interior lighting. The environment (e.g. the field) does not adequately light certain areas of the render. Therefore I'm adding additional "environment" lighting by placing light emitters around the windows. I don't want the lights be seen as white planes.
Can I exclude the light object from showing in the render but still lighting the scene?
TrippyLighting
No, that isn't possible with Fusion 360.
If you can post the .f3d file of the scene I can take a look at it.
guardian_de
Thanks again, Peter 🙂
I sent you a link to the file in a private message as the file is too big to upload.
I'm mainly struggling with this kitchen perspective:
I had some improvements when changing the HDRI (stock field as provided by F360) to something else from Polyhaven.
Also lighting in night environment is something that I fail with.
Thanks for your help!
