Does Fusion not support use of Multiple Displays?
mavigogun
Advisor Advisor
mavigogun
Maybe I'm dim- I can't find any reference to using Fusion across mutliple displays.   Is there no support for viewport(s) on a second monitor?
mavigogun
Come on- this one is a gimmie: provide a definitive answer and receive credit for an accepted solution.
iSuat
Not yet
Well... it depends, how you imagine the multi display support 🙂
I can open multiple instances of Fusion360 on the same PC, and run one on one display, and the another on the other display.
I can work on the whole assembly for example on the one, and on one Part on the other display.
The only "tradeoff" is that everytime I change, on which I want to work, I need to click into that window...
I did try this with only two displays, but i am almost certain it would work with 3 or 4 displays as well.
Also as most of the computation uses a single core only, you could change, which instance should run on which core in Windows....
Hope this answers your question,
Tamas
