Display dimension as *NUMBER...MATH OPERATION*.. instead of number in sketch?
b2744442
b2744442
I am entering dimensions with math operations with division like this:
When I finalize the dimension, it displays as a whole number. Can I instead have it be displayed as .616/2?
Thank you in advance!
jhackney1972
No, it will display in the sketch as a number but if you click on the dimension, as you would do to edit it, it will show what formula you entered.
John Hackney, Retired
b2744442
Thank you, yes I definitely know I can do that. If there is anyway to change the display default of dimensions it would save me from having to make extra double clicks. Just trying to improve workflow!
jhackney1972
No, I do not think so.  Even if you enter it as a Parameter, it only will show the following.
