Display component color option missing
shojib76
Message 1 of 10
shojib76
Suddenly i cannot find display component color option. did it change? why, thx in advance for help..Screenshot 2026-02-21 100735_issue.png
Replies (9)
Message 2 of 10
TimelesslyTiredYouth
Can you supply the file that's exhibiting the issue
file -> export -> f3d
Kind regards
Ricky
**No, the show component colours is still in the exact same spot under inspect, are you working with an assembly?
Message 3 of 10
kacper.suchomski
Hi
Why do you need a component display function when you have one component.
Kacper Suchomski
Message 4 of 10
jeff_strater
you are likely in Part Design mode.  Switch to Hybrid:
Jeff Strater
Engineering Director
Message 5 of 10
shojib76
So, even with one component, i used to be able to see color.. I think i figured out a workaround, if you open another design that has multiple components, "Display component color option comes up!", use that option theretest2.png ,  then re open the "One component" design, then , i can see color on the one component design(I dont have the option though).. here is the updated picture..
I need it for 'look' purpose.. i think i have a workaround now.
thx
Message 6 of 10
kacper.suchomski
Are you familiar with the part appearance command?
(view in My Videos)
Kacper Suchomski
Message 7 of 10
TheCADWhisperer
@shojib76
I think a video using your actual part will clear up all of the confusion.
No "workarounds" are needed.
(view in My Videos)
Message 8 of 10
g-andresen
might help
(view in My Videos)
günther
Message 9 of 10
ktabanin13
Thank you sooooooooooo much!! You just saved my day!!
Message 10 of 10
rosie_lucas1
Hello @shojib76
Just checking in—did the responses shared by @kacper.suchomski, @jeff_strater, @TheCADWhisperer and @g-andresen help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie| Community Manager
