Discussing the "Redefine Sketch Plane" problem
- Mute
- Permalink
- Report
There seem to be a number of similar threads related to "redefining sketch planes": https://forums.autodesk.com/t5/fusion-360-design-validate/redefine-sketch-plane-preview-looks-fine-t...
https://forums.autodesk.com/t5/fusion-360-design-validate/constuction-plane-normals/m-p/6434654.
I have just had the oft-repeated problem that redefining a sketch plane flipped my sketch upside down and lost its projections. Somewhat miffed, I played around a bit to figure out why it sometimes does this - see screencasts below. Judging from the response to the above posts, it seems AutoDesk might fix this annoyance at some point, so in this post I'm exploring the nature of the problem and what I would like to see in an improved version (before they do it and it's too late to make suggestions).
It seems that there are two kinds of sketch and you have no way of telling which you have (unless you can think back and remember how you created it):
- Sketch on a face
- Sketch on a construction plane
I found myself with two sketches apparently on the same plane but actually one was on a face. I had drawn Sketch 1 on a construction plane, extruded from that sketch, then created Sketch 2 on the end of the extrusion. I then decided that I would like Sketch 2 to lie on the body mid-plane so I rolled back the timeline, made a plane there and redefined Sketch 2 as being on that plane. Whoops! The sketch rotated 180 degrees about its x-axis (actually it does this if you click on a face that is solid in the +z direction but not if you use one that is solid in the -z direction, I'll come on to that).
Generally, F360 will try to do something sensible if relocating a sketch from one face to a similar face.
The problem arises if switching from a face-reference to a plane-reference, or between faces (or planes) with dissimilar definitions such that F360 does not find an obvious transformation to pick. Your sketch then rotates 90 or 180 degrees (about an axis either in the plane or perpendicular to it) and it can be half-impossible to reposition it as required using the Move tool.
Let's think for a moment about the kinds of redefinition that might be useful:
- You have a body with several similar faces (cube, pyramid etc). You start with a couple of sketches on face 1, then decide that one should really be on face 2.
- Ditto but your faces are dissimilar e.g. your "cube" tapers as seen from the x-direction but not the z-direction.
- You have a sketch on a face, then decide you want that sketch to be on a plane coincident with the face (perhaps because the face is about to be deleted)
- You want to switch from one of the xyz origin faces to an offset, angled or other custom plane
Looking at each of these:
(a), Fusion will probably redefine the sketch so it looks just like before as it sits on its face. Fine. If however you wanted to reflect it in the face1/face 2 joint line (perhaps a 3D sketch) so it was symmetrical with the original, I don't think you can do that. I don't think there's any other way of doing this either, so building it into "Redefine plane" would be a good way of providing a reflection capability.
(b) For this you would want to redefine the sketch origin (as suggested in the posts mentioned above). This could be done by the Move command, if it was tweaked slightly. To cover all possible eventualities you would want to define:
- a sketch point and a target point,
- a sketch line and a target line to which it should be parallel
- whether to flip the sketch line direction (rotate 180 deg, in-plane), or
- whether to reflect the sketch about a plane perpendicular to your target line, through your sketch point,
- pick a plane-normal direction (flips the sketch above or below the target line) and
- whether to reflect 3D components in/out of plane or preserve the original sense.
(c) If the new plane is coincident with the face plane, the sketch should not move (but as Galileo may have said "And yet it moves!").
(d.1) For offset planes the sketch should translate parallel to the plane normal. If this isn't what's wanted, the options under (b) above should sort it out.
(d.2) For inclined planes there are 4 geometrically-simple options that could map a sketch on plane 1 onto a sketch on plane 2, bearing in mind that the planes will intersect along a line "L" and that there will be both an acute and an obtuse angle between the plane normals:
- Reflect the sketch in the acute-angle bisecting mid-plane between plane 1 and plane 2
- Reflect the sketch in the obtuse-angle bisecting mid-plane between plane 1 and plane 2
- Rotate the sketch about L though the acute angle
- Rotate the sketch about L through the obtuse angle.
There are also variants that would position the sketch in one direction but give the user some choice in the second direction:
- Specify a radius of curvature (user choice) and define an "acute angle" axis of rotation such that plane 1 rolls onto plane 2 about this axis, carrying the sketch with it.
- Ditto, obtuse angle.
Basically these are the same as (iii), (iv) plus a user translation perpendicular to L.
The trouble with Redefine Sketch Plane at the moment is that it does not give you any of these choices. It would be good to have them "at the touch of a button" and pick the one you want.
To demonstrate the current behaviour I've done 3 screencasts. I think I can only insert one per message so I'll post a couple of "replies" with the others.
The first screencast (sorry, no sound) is with parallel planes and explores the difference between face- and plane-based sketches.
Screencast 1 (file "sketch redefinition v0").
I started by making four identical 2D sketches, differing only in that they sit on different planes:
- x-y plane from the front "Front of xy sketch"
- x-y plane from the back "Rear of xy sketch"
- Front face of an extrude from 0 to -z "Sketch facing -z"
- Back face of an extrude from 0 to +z "Sketch facing +z"
All these planes are coplanar (first 7 minutes of screencast).
I then selected the xy plane and made an offset plane from it, placing this at the start of the timeline so I could use it as a new sketch plane.
Finally, I go through the four sketches, redefining each to use the offset plane. The first three are fine but the "Sketch facing +z" turns upside down (7:56 minutes) - I think it has revolved 180 degrees about the sketch x-axis. Actually it does this even if I redefine onto the xy plane (coplanar with the original face) - not in screencast.
