Measure tool loop length
mike.lerwill
mike.lerwill
When I select a face which is a quarter of a cylinder using the measure tool it reports the radius, diameter and area which all make sense. Radius is 226mm, diameter is 452mm. Since the height is 45mm (which it does not tell me) it gets the area correct at 1.597E+04.
It also tells me that the loop length is 800mm but I am at a loss to work out what this actually means.
Can someone please enlighten me.
Mike Lerwill
lee_sanders
Hi @mike.lerwill
I think it's the total curve length on the surface
452 x Pi / 4
x 2
+ 45 x 2 = 800mm loop length
lee
Lee Sanders
Technical Consultant
mike.lerwill
Yes makes sense
LeonardoBN
It's the length of the face "border".
Leonardo Brunelli do Nascimento
Chemical Engineer
