dimensions
dimensions
dimensions
i am just a beginner and try to learn fusion. since the last update(2.0.7036)
the dimensions dont have desciptions like d1.
is this feature canceled? there was also a setting function to see the name of each dimension?
i wanna use is this feature to change the dimensions of many lines by changing only one.
thank you for your help.
jhackney1972
I assume your mean "sketch" dimensions.  If so, no, the Fusion 360 assigned variables are still there for all placed sketch dimensions.  They are also automatically assigned for feature dimensions also.
It would really help if you post a screen capture of what you are seeing from your application, not a screen capture of a YouTube video.
John Hackney, Retired
TheCADWhisperer
Do you have Capture Design History turned on?
hello, thank you for the reply. you are right, the picture is out from an youtube video. because i send this message from my company pc where fusion360 was not installed.
the solution was this
https://knowledge.autodesk.com/de/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/...
but thank you for your help.
br georg
