constrained parametric pattern
janos.adelsberger
janos.adelsberger
I basically need a way to do a pattern in a sketch but following a curved line.
What I'm trying to accomplish is creating a laser cuttable dxf but parametric so I can change the distances of the living hinge quickly. The result should look something like that which I built manually.
I'm pretty much stuck with this so far as I can't come up with a way to make these construction lines follow the curvature of my edge. The everything else shouldn't be a problem...  Any ideas of how to do that? By the way, this is my first time posting so I'm not even sure if this is the right forum...
etfrench
This thread may help.
ETFrench
