Dimensions not showing in Render
First off, I'd like to disclose that this is my first time using fusion 360 or any CAD program for that matter...
Anyways, I'm modeling a glider and as part of my project, I need to supply isometric and orthographic drawings. Once I had made all the individual components of the gliders I assembled them all in a new workspace. I then went into each component and created dimensions on three sketches each with a different plane (for top view, front view, and side view).
My problem is trying to get these drawings. I can just take screenshots on the workspace but then that isn't to scale, and when I render it (haven't figured out how to render to scale but I presume you can?) my dimensions don't show.
Just wondering whether anyone more experienced could help me figure out how best to do it?
Thanks so much
lucasliraAU
Hi @Anonymous
Thanks for reaching out to us on the forums!
I recommend you view this tutorial in this video lesson you can find the elements that you are needing for the completion of your work!
Hope this can help you!
Greetings!
Did you find this answer helpful? If so, please use the Accept as Solution or LIKES button below.
Si esta respuesta te ha servido de ayuda, por favor márcala como Solución Aceptada o dale a LIKES
____________________________________________________
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
