- Mute
- Permalink
- Report
Hello!
Feeling a bit lost as I try to make a simple drawing to describe the angles and lengths of this chair I have attached, since the features I need to dimension are not flat to orthogonal views.
Look at the legs, you can see that they are splayed out about 60 degrees. They are also subtly rotated, though I don't think you can tell from these images. The legs were created from flat sketches, for which I would hope I could find orthagonal views in the drawings environment so I can explain their specific angles and lengths. The same issue goes for the egg-shaped top of the chair, I can't easily view it "flat" so I can give proper dimensions for its radiuses, etc.
How would you deal with this issue? Thanks for any help!
