Another constraint bug - coincident constraints not being obeyed
robduarte
robduarte
As I said earlier this week, I'm trying to show reproducible examples of constraint issues. The previous one was verified as a bug - please let me know if this is also a bug or if I'm missing something:
The youtube video that demonstrates the problem:  https://youtu.be/KxAGP0NX5-k
Here is the public link to the design:  http://a360.co/2263OPi
Thanks!
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
promm
Thank you @robduarte for brining this to our attention.  We are looking into it and will follow up with what we find.
Thank you,
Mike Prom
promm
@robduarte,
When an endpoint is constrained to a line, the "line" in infinite.   Meaning when you drag it, it will not stop at the endpoints.  Collinear constraints can only be created between two lines, you cannot have a collinear constraint between a point and a line. This is as designed and considered the standard across CAD packages. I would suggest adding a dimension to the point if you do not want it to move when you drag.  In your video when dragging the sketch, you see the sketch flip, that is a bug and a known issue.  This is due to the speed of the drag affecting the compute and we are working towards a solution.
What is shown here is correct.
http://autode.sk/1UiyPNs
Cheers,
Mike Prom
robduarte
Thanks for the clarification. I'm not dealing with colinear constraints but the idea that coincident constraints are constrained to a line and not a line segment was something I didn't know about. The flipping was a separate problem that I was experiencing - glad you're working on it.
Rob Duarte
Twitter | YouTube
