- Mute
- Permalink
- Report
I'm using a coil to define parametric threads on a body that can be varied in OD by a user parameter. In general that part is working fine.
However, when the center of the cylinder the threads are placed on is shifted (as a part of the user controlled design variables), it all breaks because there appears to be no way to dimension or otherwise constrain the center point of the coil. This is frustrating because it appears that Fusion effectively creates an "internal" sketch to build the coil, but doesn't let the user interact with that sketch.
I'm thinking that this is a limitation of the software, but I wanted to query the hivemind to see if there is something I'm missing.
I also thought to just create a 3D sketch of the path to sweep the thread profile, but it appears the AutoDesk recommended way to achieve a 3D coil sketch starts with a coil which puts me back where I started. Maybe I need to figure out how to create that 3D coil sketch myself parametrically.
