- Mute
- Permalink
- Report
I'm having trouble getting off the ground when it comes to adding dimensions to my 2D drawings of my parts. This is something I'm used to breezing through in Solidworks, but I am forcing myself to learn it in Fusion since I need/want to 'jump ship'.
I've reviewed similar posts that had trouble with adding dimensions, but the explanations in those threads confuse me more than help. I figured no harm in asking for an explanation that applies to my situation. What about my object doesn't allow the program to 'see' the edges I'm interested in snapping to, in order to create a dimension? Is it because they are all technically radial surfaces? If so, how the heck do I go about this? I saw mention of a work-around with named views, but do no understand the explanations in those threads. Do I need to change the drawing views I am using to attempt to dimension off of?
Base object, a shaft
Barely able to get 2 dimensions out of this!
Intended level of dimensioning needed
