Dimension ZERO
Dimension ZERO
San_Escobar
Message 1 of 16
Dimension ZERO
San_Escobar
Hey Fellower.
I just tried all the way but seems that Fusion 360 doesn't allow to enter Zero Dimension.
Than I though would be great to have such option, other than use 0.0001mm as dimension. 🙂
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
Replies (15)
Message 2 of 16
rishivadher
Hi
where is the logic on a dimension been "null"
its like 2=1 by proving
if a=1 and b =1
a=b
a^2=ab
a^2-b^2=ab-b^2
(a+b)(a-b)=b(a-b)
a+b=b
2b=b
2=1
at maximinum geometricaly you can define the angle as 0
Message 3 of 16
Jon.Dean
Hi Aqhead,
I agree, it should work, does with most CAD packages.
Instead of using dimension = 0 you could use the constraint "Colinear".
I'm not sure why Fusion 360 does not allow the use of zero.
Jon.
Jon Dean
Message 4 of 16
Silvio_Brasil
I know this post is archaic but I dont understand why it is marked as RESOLVED!!! since I also like Dimension 0 and Fusion just lack about it...
I recently update my FUSION 360 and not improvement in this end, :S
Message 5 of 16
airesgabriel
Observer
Observer
It would be great if it was possible with fusion just constraint something coincident, but in fact it's such an hard task. It's mandatory to create construction geometries and then use the colinear constraint Smiley Frustrated
Message 6 of 16
HughesTooling
There is a workaround, add the dimension to the sketch as 1° then open the parameters manager and change it to zero.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 16
lichtzeichenanlage
I'm new to CAD and I have an idea why this could be useful (e.g. for defining clearances) but I'm curious to know what's the "real" need behind this request.
Message 8 of 16
HughesTooling
For me one use is experimenting with the position of a feature, you might want to try a zero offset or even a negative one. These work as parameters already, if you're using several parameters to calculate a position there's always a chance you'll get zero or a minus number. The problem at he moment is the dimension input doesn't allow zero or negative input.
Mark
Mark Hughes
Message 9 of 16
lichtzeichenanlage
@HughesTooling: Thx for the reply. That sounds useful. My workaround is to use the offset feature. That can take positive, zero and negative values.
Message 10 of 16
HughesTooling
@lichtzeichenanlage You're only thinking about one case and actually you can't go back and edit an offset and enter a negative number to swap the offset. I had a job a while ago that needed several sections to form a curved loft and dimensioned off projected points from previous section, some needed zero or negative offsets.
Another workaround is to toggle a dimension to Driven drag the point to the other side then toggle back to driving and enter the size.  Doesn't work for offset though!
Mark
Mark Hughes
Message 11 of 16
lichtzeichenanlage
I'm not a professional or an expert. So for sure I don't think through all cases because I don't know them. And I'm / we're talking about workarounds and those are limited by definition.
@HughesToolingwrote:
@lichtzeichenanlage You're only thinking about one case and actually you can't go back and edit an offset and enter a negative number to swap the offset. ...
You can by using the parameter editor.
...I had a job a while ago that needed several sections to form a curved loft and dimensioned off projected points from previous section, some needed zero or negative offsets.
Sure, offsets are not working with points. You could draw a line through the point and offset the line, but that' an even worse workaround.
@HughesToolingwrote:...
Didn't know this one. Have to try it but doesn't sound clean either.
Message 12 of 16
MichaelT_123
Hi Fellows,
Traditionally, a dimension is considered to be a positive rational number, reflecting associated physical phenomena of acquiring it in a very physical world.
That said, applying such concept directly to the abstract world of CAD design only asks for troubles as evidence(s) show.
By extending the dimension's value to the whole domain of rational numbers, would allow a great simplification not only F360 internal algorithms but also night dreams? of many CADs aficionados.
Regards
MichaelT
MichaelT
Message 13 of 16
manoxFMZTG
I work with Fusion and NX (Unigraphics). Many years ago (I think about 2010-12) NX add possibility to use negative value of dimenssions. And this is very usefull, for example to change side of line or point to base point.
When You must find right position of line (or other element) and change side for it: You must change dimension to driven, change side, change to dimesion to drive and change value. Very many changes... Easier is write "-".
Other way: in the sketch this is problem, but in extrude it's fine?
The same thing with zero value - sometimes You must change position of circle, and You have dimenion with some value. For change it to zero - You must delete dimension and add colinear. When You change conception - in opposite direction.
I see - post have 6 years. And now with configure table possibility use negative and null value could be more usefull than six years ago.
Best regards
MANok
Message 14 of 16
MichaelT_123
Hi Mr ManoxFMZTG,
The ZERO(s) issue is ambivalent ... not only in the Fusion world but also in the World outside.
Do we really need them? It is the question for mindfulness philosophers to contest.
If you want to study it sedulously ... here are other posts about the subject:
https://forums.autodesk.com/t5/fusion-design-validate-document/constrains-direction-flipping-with-ch...
https://forums.autodesk.com/t5/fusion-design-validate-document/sketch-constraint-violated-when-chang...
https://forums.autodesk.com/t5/fusion-api-and-scripts/natural-numbers-voice/m-p/11522033
... and by the way ... do not treat them with ZERO margin of solemnity.
Regards
MichaelT
MichaelT
Message 15 of 16
busycleta
Hi Michael
It is absolutely not ambivalent, here is why:
Imagine you are an audio engineer, you have many channels in the mix but the faders all the way down don't produce a zero-output signal.
-- instead this results in having an ever so slight signal of each channel on the master mix, even tough it should not be present at all.
In same way engineers want to have full control of there CAD Sketches as expected from any other CAD System, there is no possible benefit to be gained from restricting zero as a dimension value.
Greetings
Message 16 of 16
MichaelT_123
Hi Mr Busycleta,
I have an itchy feeling ... that you misunderstood my position about ... ZERO.
Regards
MichaelT
MichaelT
