dimension control not working when i press d
james.j.harris95
james.j.harris95
have just started to learn fusion ,i am a beginner trying to follow tutorials ,seem to loose the dimension shortcut when i press d nothing happens when used previosly  , tried  restarting 360 but still have no dimensions when i press d , please help getting very frustrated
Accepted solutions (3)
RobDraw
This is the AutoCAD forum.
Rob
laughingcreek
I guess this got moved to the fusion 360 forum.  the shortcut d only works if you actively editing a sketch. are you?  some screen shots might help to under stand your problem.
shahriarsifat1802164
Make sure you are in the sketching environment.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
james.j.harris95
thanks for the replys , finding this a steep learning curve as have not used a cad program for 20 years and its a bit differant now!
james.j.harris95
many thanks realize it was an error from me now
