Hello everyone - Design Suggestions
FacebookGroupMember
FacebookGroupMember
Hello everyone.
I am an absolutely beginner with Autodesk F 360. I am also an headteacher at a secondary school with a MakerSpace. In this MS we have a cnc mill and my first design shall be simple 2D design that I can make the cnc read and mill. Any suggestions?
laughingcreek
What kind of cnc mill do you have?
are you lookng for a suggestion of something to design, or are you looking for information on the whole process of going from design to finished part?   the wording of your question suggests your not familiar with the whole process.  obviously could be wrong about that.
FacebookGroupMember
If you are looking for basic starter projects to run on a mill then take a look at https://academy.titansofcnc.com/
FacebookGroupMember
ICanSpinIt
Your CNC limits you a little bit. For starters and simplicity grab some MDF and start engraving.
If you are looking to program Titans Academy is a good place to learn tool pathing.
Just make sure your using the correct post processor. You could send the machine in the wrong direction. You can find them at the fusion360 post processor library. Look for a machine from a manufacturer listed that has the same controller that you have. Just be cautious the first time you use it for every tool path
chrisplyler
Make yourself a fancy plaque to hang on your wall, that recognizes your great achievement in plaque making.
