Dimension constraints on faces of 3d body?
Hi. I have an irregularly shaped body that's effectively a loft between multi-segmented lines, the bottom of which is tangent to an ellipse (on the XY plane) and is effectively fully constrained. Essentially, it's all derived from a flat pattern that's wrapped around the ellipse. The line segments have a fixed length on the XY and should have a fixed angle on each facet (highlighted below).
How can I dimension the highlighted angle, per facet, to effectively adjust the overall shape of the top?
