Different materials blurred together after rendering
Hi all
I'm Joe a beginner fusion user Started using it for visualise my furniture designs
I ran in to a problem when I tried to make a walnut table top with a maple inlay
After rendering the two materials/appearance is blurred together. But even in the model view in some angels it's not perfectly visible
This is just a sample to show the issue
Before Render
After Render
In Model view different angle
The maple bit is a new body extruded in to the other body
I'm aware it can be an issue when two different body sharing a plane but I could't fix this anyhow
I tried to play with the environment I had some okay result but still way to much blur
It might be something very simple sorry if it is. I did my search here but I could't find a solution
Any advice would be highly appreciated
Thanks reading
Joe
SaeedHamza
There isn't a way around this, there isn't even a need to think of one!
If there are 2 render materials on the same plane, that means one of 2 things :
1- There are to bodies, and the bigger body should be combined with the smaller body, and the smaller body as the cutting tool, while keeping the tools in the combine dialog box checked
2- This is one body with 2 different materials, and the small area that has a different material than the rest of the body is created using the split face command
Regards
Saeed Hamza
Dear Saeed
Thanks for the reply
Would you mind to do a quick screencast how to do it exactly I'm not sure I got it right
Many Thanks
Joe
SaeedHamza
Sure, here is a screencast
I hope it helps
Regards
Saeed Hamza
Thanks Man! You are a legend! It worked 🙂
Thanks for taking the time!
Cheers
Joe
