Can't create flat pattern anymore. Plus edit Flange, Extrusions, on part.
I'm new to Fusion 360 and I need to make a part from 10mm thick sheet metal. I'm used to Inventor where I could start the part in a normal ipt part then switch it to a sheet metal part and I did the same here. The part I'm making was to be made from 9.5mm thick carbon steel but has since been changed to 10mm. I was able to edit the extrusion by pulling it as such out 10mm (took me a while cause I'm used to seeing "Extrusion 1" etc on the sides, and I changed the sheet metal rule to 10mm thick sheet. But when I create the flat pattern, it now doesn't flatten the entire part. It also doesn't let me select the initial extruded face of the part to be stationary when I make the flat pattern anymore, and only selects the phase made from the flange command. Could someone please help me with this? And also tell me how you can edit a created flange, if supposing you want to change how long you made it?
Images are attached to show the part.
