I've noticed some bug or at least unexpected behavior when using as-build-joints.
The situation I quite often have is, that I have multiple "assembly"-components (each with a sub-structure of components linked by various joints) which I then want to join together on the "root" level by joints as well. It works fine with "regular" joints or with "as-build-joints" when I select things in the model-view, however, I naturally often selecting things in the browser-list and then it does not work.
The typical work-flow:
- Click "as-build-joint"
- Click two components (on root level) in the browser
- Select joint type (i.e. rigid)
- DONE.
If you do it like this (see the screen-cast), a "joint" is properly created on the root-level, but it is "empty", i.e. it does not link anything. As a result, the sub-components can still move freely around.
This has confused me a lot for a very long time until I realized that I have to either use "regular joints" or select the "as-build-joint"-components by clicking in the view, but not in the browser.
