Help with combining joints
When I use two types of joints on one assembly it kicks an error. I included the link to the test assembly. Any help is appreciated.
http://a360.co/2fGXOvE
just trying to rotate the upper wheel and control motion of bar with pin-slot
thanks,
chris
laughingcreek
I got it to sort of work by un-grounding component 5.  to get it to not move (as if it were grounded) I added an as built ridged joint between it and the grounded joint (component 3).
Then I at least didn't get an error when applying a slider joint between component 1 and component 4.
still some funky ness going on though.
Thanks for trying.
Yes , i can't get it to work either.
