dialog box too narrow to read
Message 1 of 18
I'm just starting a trial of Fusion. While attempting to do several operations I am presented with a dialog box that is too narrow to display the contents (See vertical bar in front of the half-hull). I've tried dragging it wider but it won't drag, I've tried hitting the (+) icon a the top but it disappears when moused over.
In this particular example I would like to mirror the hull, but the options are unreadable and clicking where it says |RRO| or |NFO| has no effect. I assume the dialog box is meaningful otherwise it wouldn't be displayed.
Any suggestions would be appreciated.
Replies (17)
Message 2 of 18
HughesTooling
Did you try dragging the bottom right corner to resize. You could try to reset the layout Ctrl+Alt+R
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 18
Dragging corner was the first thing I tried, I just tried again to confirm. I can not change the size. I tried ctrl+alt+r. Nothing.
Intermittently, when I click on the lower part where it shows |NFO| I will get a dialog popping up on my other monitor telling me "Select the objects to mirror...", a button for "More Information", and another button "Cancel". However, as soon as my mouse leaves the narrow box, this new box disappears.
Message 4 of 18
HughesTooling
I had something similar happen to the comment dialog a while ago, I think closing and restarting Fusion fixed it. Might have need to reboot my computer as well, can't remember.
Mark
Mark Hughes
Message 5 of 18
I've tried quitting and restarting Fusion to no avail earlier. Right now I am trying to quit Fusion to reboot but it won't let me because the dialog box to save the project won't appear. I'm forcing a quit as there was nothing there I really needed to save.
Message 6 of 18
I just Force Quitted, and restarted, the dialog boxes are still narrow and unreadable.
In the interest of science I also tried shutting off my second monitor, quitting and restarting. No change.
Message 7 of 18
HughesTooling
@innovatenate any ideas on this problem?
Thanks Mark
Mark Hughes
Message 8 of 18
innovatenate
Autodesk Support
Autodesk Support
@HughesTooling Thanks for tagging me! I've never seen this before!
@Anonymous Thank you for posting about this and I'm sorry that this is happening.
I'm curious if you close the Getting Started window if the behavior changes.
If you dock the dialog, does it look any different or respond to trying to change the size of the dialog? See the below link for help with how to do this. It does assume that you can drag the dialog somehow.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Can you tell me more about your system? There's a graphics diagnostic command in the help menu. There's a copy to clipboard command that will copy information about your system's graphics cards. Can you paste the results in a reply?
If you use the Open in Low Resolution mode, does that help?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Per...
Any chance you've tested just restarting the computer (full hardware reboot not restarting Fusion)?
If none of that helps, I think performing a clean uninstall (see automatic tool here) and then re-installing may also be another good test. Perhaps something went wrong during the install...
I'm very interested to see your response. Please let me know if you have any questions.
Nathan Chandler
Principal Specialist
Message 9 of 18
It is the same with the Getting Started window closed. Docking/Undocking does not seem to have any effect.
I have done a full hardware reboot as well as quitting and relaunching Fusion.
I've had a couple crashes during this process, I've sent the crash reports.
I just tried restarting in Low Resolution mode and now I can not see the top and left side of the Fusion window and can also can not reach the top of the window to move it to where I could see it. (screen capture below the system reports) When I switched back out of Low Res mode the problem persisted. I'll try a hardware reboot again.
[GPU Information]
GPU Device: AMD Radeon R9 M370X
GPU RAM: 2048 MB
GPU Driver API: OpenGL
[Graphics Effects Settings]
Use high-resolution graphics: Off
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: On
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
Hardware Overview:
  Model Name: MacBook Pro
  Model Identifier: MacBookPro11,5
  Processor Name: Intel Core i7
  Processor Speed: 2.8 GHz
  Number of Processors: 1
  Total Number of Cores: 4
  L2 Cache (per Core): 256 KB
  L3 Cache: 6 MB
  Memory: 16 GB
  Boot ROM Version: MBP114.0172.B10
  SMC Version (system): 2.30f2
AMD Radeon R9 M370X:
  Chipset Model: AMD Radeon R9 M370X
  Type: GPU
  Bus: PCIe
  PCIe Lane Width: x8
  VRAM (Total): 2048 MB
  Vendor: ATI (0x1002)
  Device ID: 0x6821
  Revision ID: 0x0083
  ROM Revision: 113-C5670E-777
  Automatic Graphics Switching: Supported
  gMux Version: 4.0.20 [3.2.8]
  EFI Driver Version: 01.00.777
  Metal: Supported
  Displays:
Color LCD:
  Display Type: Retina LCD
  Resolution: 2880 x 1800 Retina
  Retina: Yes
  Pixel Depth: 32-Bit Color (ARGB8888)
  Main Display: Yes
  Mirror: Off
  Online: Yes
  Automatically Adjust Brightness: Yes
  Built-In: Yes
VX2025wm:
  Resolution: 1680 x 1050 @ 60 Hz
  Display Serial Number: Q6Y062506578
  Mirror: Off
  Online: Yes
  Rotation: Supported
  Automatically Adjust Brightness: No
Message 10 of 18
After a hardware reboot the top and left of the window is still off screen.
I will attempt an uninstall use the tool at the link you provided.
One piece of information which may be relevant: When I downloaded the app from the OS X app store it seemed to hang up at the very end. In Launch Pad it showed as "Paused" but in the "Purchased" window of the app store it allowed me to Open. The "Paused" notification persisted in Launch Pad even after a couple reboots, but it currently shows as fully available in Launch Pad.
Message 11 of 18
I've now run the clean uninstall application, thrown away the application, run the clean uninstall again, reinstalled the app via the app store, run the uninstall again for good measure. The narrow dialog box issue still persists.
It is a shame. I like a lot of what I see in Fusion 360, but I can't use it because a simple dialog box won't work.
Message 12 of 18
innovatenate
Autodesk Support
Autodesk Support
Have you done any customizations to fonts on your system? I need to track down which font is used in the dialogs, but I'm wondering if Restoring the Standard Fonts in the Fontbook might help.
https://sayzlim.net/restore-default-fonts-mac/
I'd really like you to use it too! I hope we can get to the bottom of it. Your system looks more than adequate to run Fusion 360. I wish I had a solution in hand, but I haven't run into this one before. Thanks in advance for being the guinea pig and sorry for the troubles!
Nathan Chandler
Message 13 of 18
I have fonts I use for various projects that are not contained in the original system, but I have not done customization in terms of removing standard fonts or modifying existing fonts.
That said, I "Restored The Standard Fonts". No change. Rebooted the hardware, no change.
Message 14 of 18
This issue was not resolved before my trial period expired, therefore I have been unable to evaluate the product and can not determine if Fusion 360 is appropriate for my needs. Thank you for your time.
Message 15 of 18
innovatenate
Autodesk Support
Autodesk Support
I consulted with the development team, they recommend to delete a specific file after resetting the fonts.
Can you try to delete the following file off of the system and then start Fusion 360 to see if there is any difference?
Macintosh HD > Users > *** > Library > Application Support > Autodesk > Neutron Platform > Options *** > NULastDisplayedLayout.xml
I hope that helps!
Nathan Chandler
Message 16 of 18
I can not test this because my free trial period has expired.
Message 17 of 18
innovatenate
Autodesk Support
Autodesk Support
I've extended your trial 30 days. Can you give the suggestion a try and let me know if it helps?
Nathan Chandler
Message 18 of 18
Thank you for the continuation of the trial period. Before deleting NULastDisplayedLayout.xml I went ahead and tried Fusion. It requested and performed an update before starting. The dialog boxes worked fine, I was able to perform the mirroring operation I was originally attempting to perform and dialog boxes for other functions appear to be displaying correctly.
Unfortunately, this does not help you in debugging my original issue, but at least I can resume evaluating Fusion for my requirements. Thanks.
