Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Another newbie question about joints
1 REPLY 1
225 Views, 1 Reply
I am stuck. There is a joint that has created an error. When I edit the joint it says one of the faces/points is missing, shows a red arrow and a partial text that says something is missing. It will not let me selected the point to redo it. I can select the other point in the dialog (or really deselect) but the one that is missing simply will not let me do anything about it. In the past I have simply deleted the joint and re-did it from scratch but I was wondering how I am really supposed to fix it.  Attached is a screen shot. Notice everything is ghosted out, even the point it knows about
Thanks in Advance
1 REPLY 1
TrippyLighting
No screenshot attached. In general it is even better too share the model. You can export it as a .f3d and attach it to your next post.
