Desktop Layout
Desktop Layout
Message 1 of 8
Desktop Layout
I was following a youtube beginner video and all was going well until I hit something and now its all gone awry. First,my design is now above the redline instead of below causing issues down the road. Secondly, my grid is huge so that when I set a line length to 5mm it runs off my desktop. I have deleted all my previous projects,uninstalled and reinstalled 360 to no avail. Any help or guidance much appreciated.
Replies (7)
Message 2 of 8
jeff_strater
we'll need more information to help you.  Can you share the design here, and record a screencast of what you are seeing vs what you expect to see?  I'm not sure what "my design is now above the redline instead of below" means.
Sharing more information will definitely help us help you make progress.
Jeff Strater
Engineering Director
Message 3 of 8
TheCADWhisperer
@Anonymous wrote:
1. I was following a youtube beginner video
2. my design is now above the redline instead of below causing issues down the road. Secondly, my grid is huge
3. so that when I set a line length to 5mm it runs off my desktop.
1. You should always cite the reference (and timestep) just like in school when writing a paper.  What is the url to this video?
2. You can click and drag endpoints to the red line (or wherever needed). Click and drag and observe the behavior.
3. You can use your mouse wheel to zoom out so that it does not run off of the desktop.  Turn your mouse wheel and observe the behavior.
And as @jeff_strater indicated, when all else fails File>Export and  Attach your *.f3d file here and create a free Screencast Recording of the behavior that you observe.
Message 4 of 8
Message 5 of 8
Message 6 of 8
TheCADWhisperer
It looks to me like you are OK so far (first line).
Where are you having difficulty?
Message 7 of 8
I am trying to create a stamp like the one on the youtube video. Somehow i cha nged something so that it creates a box instead of a line when i press the l key
Message 8 of 8
TheCADWhisperer
Can you create a Screencast Recording of the behavior that you see?
What happens if you select the Line command glyph rather than use the L shortcut?
