- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello guys,
I hope you will be able to help, I am struggling since months to design an oil and gas vessel hull.
I am working for a friend on a project to design and 3D print a mould in order to use resin and fiber glass to do a model.
My friend even paid some contractors on Malt and Fieverr but all of them were unable to deliver a proper file usable and editable. I am able to get a nice form myself but it's buggy and I cannot use shell fonction or combine to get a mould shape.
I need to design the master first (the hull) so I can either directly 3D print it or get the mould shape and 3D print it.
I tried with solid, surface and form but end up with the same issue. The 2 files attached are the same design but with 2 different loft approaches:
- Using only 2 profiles with 4 rails and sketches used as template for rails position.
- Using mainly profiles and multiple lofts: I get a form but top and side are not flat and shelf function is not working.
2profiles+rails
only profiles
Option 1 results in a non valid form:
non valid form
Option 2 seems better but the top and side are 1 flat surface + the last loft create a curve on top edge when it should straight.
option2
non flat surface
The 2 f3d files are attached, I really hope you will be able to support.
BR
Laurent
