Designing a compound curve?
pfurrieKXJFT
Observer Observer
Message 1 of 8
pfurrieKXJFT
Observer
Observer
Trying to figure out how to add another curve perpendicular to flat and curved section shown below:
Here's the sketch I wanted to use to extend that blue face outward:
I had added the curve to the straight part of the surface, but couldn't figure out how to continue on through the curved surface.  And to make things even more interesting, it would be great to not only continue it on that curved area, but for that second curve to diminish as it moved up the curved face.
This does sound confusing, but ironically, if I could draw it, I could show you what I mean.
Replies (7)
Message 2 of 8
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
Message 3 of 8
johnsonshiue
Hi! If I understand your request correctly, you may want to take a look at Ruled Surface and Project to Surface workflows. The Ruled Surface allows you to create a protruded surface based on a selected loop (sketch geometry or edge) at any distance and any angle. Project to Surface allows you to project the edge to a selected face.
Please share the f3d file here so that the forum experts can take a closer look.
Many thanks!
Software Test Engineer
Message 4 of 8
pfurrieKXJFT
Observer
Observer
I've attached the requested .F3D file to the original post.
Message 5 of 8
pfurrieKXJFT
Observer
Observer
Thanks.  I've attached the requested .F3D file to the original post.
Message 6 of 8
johnsonshiue
Hi! I am sorry I don't quite follow the requirement. Are you trying to round off the edges like the attached image?
Many thanks!
Message 7 of 8
g-andresen
Take a look at sweep tool
günther
Message 8 of 8
g-andresen
Here is a demonstration of a sweep process
günther
