Designed Sewing pieces for a fabric cutter machine, I need to convert hundreds of files to single line drawings. Is this possible with a simple command?
jordan.matheson
Observer Observer
jordan.matheson
Observer
Observer
Title explains it at a high level.
But the problem is that when the files were drawn, all the features of the files are choppy lines (example attached).
Is there a way to join all the lines so that our fabric cutter doesn't try cutting the files as little mini cuts, and instead cuts in one smooth cut?
TrippyLighting
So these "drawings" were created in Fusion 360?
tommVS2MB
Fitting a curve to points is an interesting topic.  The usual measure of the fit is minimal least squares.
And frequently the curve used is a spline.
So I suggest that what you want to compute is the spline that minimizes the sum of the squares of the deviations across more than 2 points.
It is an interesting and not uncommon  math problem.
This applies to 3d and n-dimensional too.
etfrench
One way to do this is to:
  1. Extrude each piece.
  2. In the Mesh workspace, select CREATE/Tessellate.
  3. Select CREATE/Create Mesh Section Sketch.
  4. In the Solid workspace edit the new sketch.
  5. Select Fit Curves to Mesh Section.
This may be able to be done with a script.  Ask in the API forum.
ETFrench
jordan.matheson
Observer
Observer
Yes, they were originally drawn in Fusion 360.
etfrench
What format is your "drawing"?
Another possible fix:
Convert these to continuous line/curves/splines by making all of the end points coincident. Try it with one file to see if that works for the fabric cutter machine.
ETFrench
TrippyLighting
Interesting! Can] you share the design ?
Export as .f3d and attach to your next post.
