Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Design showing mashing error with unknown discription.
3 REPLIES 3
sadibhuiyanbd
180 Views, 3 Replies
sadibhuiyanbd
Hello everyone,
I'm trying to run a simulation with this design but every time the simulation shows mashing error with no description.
below is the link o my design that I'm working with.
https://a360.co/4d9J03X
Can anyone help me out please?
Hello everyone,
3 REPLIES 3
henderh
in reply to: sadibhuiyanbd
henderh
Hi @sadibhuiyanbd,
Thank you for providing the model. The reason for the mesh failure is due to problematic geometry.
The Inspect > Validate command in the Design workspace detected an 'invalid surface'. If the Repair option is chosen, the surface can be repaired.
Afterwards, the mesh can succeed.
Best regards,
Hugh Henderson
QA Engineer (Fusion Simulation)
Hi @sadibhuiyanbd,
Best regards,
Hugh Henderson
sadibhuiyanbd
in reply to: henderh
sadibhuiyanbd
Thank you for your advie. it worked perfectly.
sadibhuiyanbd
sadibhuiyanbd
Thank you for your advice. it worked perfectly.
