Design issue
Design issue
Design issue
Hello All,
I'm a beginner in Fusion 360 and I'm facing some issues while designing water dispenser. I'll be extremely thankful if you can help me out with my design.
I have attached the images for your reference. I'm unable to flatten the tip of the Water dispenser Pencil. Kindly help me out with this.
Awaiting for your reply.
lichtzeichenanlage
  1. Create an offset plan from the bottom at that height you want to cut
  2. Use that new plane in "Modify -> Split Body" to cut the tip
  3. Right click the top in the browser and use remove to eliminate that part you don't want to keep
jasonhomrighaus
Create your pencil then create a drawing on the end of it, in this case a triangle, then extrude the triangle and set the taper angle to a negative number that fits your design, then use split body and the pencil shaft to trim the edges,
Thanks a lot 🙂
