Design help
Design help
omarhusseinramadan
Design help
omarhusseinramadan
Hello, I’m currently doing the ‘Introduction to Mechanical Engineering Design and Manufacturing with Fusion
360’ course on coursera. It is about autodesk fusion design and focus more on mechanical engineering, a part of it includes creating renders, joints, animation, as well as creating and simulating toolpaths and simulations in general. The course link: ' https://www.coursera.org/learn/mechanical-engineering-design-manufacturing/home/welcome
However I’m struggling with the first design challenge (attached below).
instructions:
I have already started the challenge and this is what i have so far:
I need help removing the areas circled please.
Or please help by sending step by step instructions.
jhackney1972
You will need to attach your model.  The Coursera site is not accessible to the Forum users unless they have an account.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
g-andresen
try this
günther
