Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Design Assist
6 REPLIES 6
a_aggarwal3D2P2
224 Views, 6 Replies
Design Assist
Good Day
see enclosed photo of item that i need to model. I have written some dimension on attached photo.
I need assistance in modelling this part please. it is made from 10mm steel
6 REPLIES 6
Drewpan
in reply to: a_aggarwal3D2P2
This looks reasonably straight forward to model, as long as you know the shape of the end that enters the tank. It
seems to be square like so is the 151mm long edge the same on both sides? What is the measurement of the top of
this shape?
If it is a circular pipe that connects to square opening on the tank then a simple loft or sweep should work. Simply
put the circular end on a sketch on one plane. Create another Offset Plane 415mm from this plane and create a square
or rectangle with the measured dimensions. Fire up the loft or sweep command and it should work. If it does not work
then you may need to draw in a couple of Rails between the two shapes.
Cheers
Andrew
a_aggarwal3D2P2
in reply to: Drewpan
HI Andrew
Thanks for coming back to me
Please see enclosed tough sketch for the same
[cid:image001.jpg@01DAD46C.CAF43750]
Drewpan
The file is not attached properly.
a_aggarwal3D2P2
Hi Andrew
the file didnt attach properly
wersy
Probably a smooth flange was used with a 273x4 mm pipe section.
Edit
The pipe must be 10mm.
So this is a very robust construction.
Do you want to create a sheet metal?
wersy
@a_aggarwal3D2P2  schrieb:
Hi Andrew
Don't use cid file.
Try jpg as you did before.
Technology Administrators
