Deleting T-Spline Faces
TOwens777
TOwens777
Is there anyway to "lock" the shape of a t-spline body so that it does not change when you delete a face?
Oceanconcepts
You can create T-specific spline shapes that are stable when a particular face is removed, but from what I understand of how T-splines work, I don’t think that would be possible as a general case.
What are you trying to achieve? Is it possible that converting to a solid, you could accomplish it in the Model workspace?
- Ron
Mostly Mac- currently M1 MacBook Pro
TOwens777
I'm creating a torus.  I want to use the bottom as a cutting tool to "dish out" an area.  Part of the outside intersects with a portion of my body that I don't want cut.  I want to remove that part but retain the overall shape.  I will try converting it to a solid and see how that works.  Thanks for the suggestion!
PhilProcarioJr
Convert it to a solid and cut out the area you don't need. That will definitely solve your problem.
Phil Procario Jr.
Owner, Laser & CNC Creations
TOwens777
That worked.  Thanks guys!
