Deleting a component gives warnings for unrelated joints
storeyp
Autodesk Autodesk
storeyp
I've got a component I want to replace. Rolling back the timeline and deleting it creates all sorts of warnings with joints that, to my knowledge, have no relation to the component I deleted. If I try to redefine the joints, there doesn't seem to be a problem, but when I click Ok, the warning remains.
I've also tried to do the lazy thing of removing the component, but it's not an option for this imported component, and I'm not sure why.
Any advice? Thanks.
TrippyLighting
We're never shy of advice around here 😉
Please share your designEither export as .f3d and attch to your next post or share via the data panel.
Beyondforce
Hi @storeyp
When you create a Joint, you create a relation between two or more components. That component could also be a reference to another component or sketches.
If you want, you can attach your file and I'll look at it.
Cheers / Ben
Check out my video channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
storeyp
Are either of you guys on Skype for Business? Could you drop me a message?
innovatenate
Autodesk Support
Autodesk Support
If you are looking to keep your design private, you could share a public link via private message in the forum. If you select the username, there is an option to send a private message in the contact panel. I'm happy to take a look as well. Just let me know.
Nathan Chandler
Principal Specialist
Beyondforce
Hi @storeyp,
Perhaps this will help you: https://www.youtube.com/watch?v=zZfNC4R2sg8
Cheers / Ben
Ben Korez
| YouTube
