Deformation Scale Description
I am aware that 'adjustments' on simulations section make deformations visually visible, but I am curious about the scaling factor to achieve this. Most specific information on the the topic I could find was a scaling factor for 'Adjustment':
"The deformation scale is a function of the model's bounding box size and the actual maximum displacement magnitude. Specifically, the scaling factor equals 0.5 * (the bounding box diagonal length) / (the maximum displacement magnitude)."
I'm not sure I understand. What exactly is meant by the 'bounding box diagonal length'?
Thanks!
TheCADWhisperer
TheCADWhisperer
