Message 1 of 9
Hi!
I've created the red component as a part of an assembly, it is quite dependent on other parts and has to be drawn in the current orientation. The problem is that when I export the component as STL and import it in Simplify3D I would like to define the baseplane where I placed the construct plane. Is it possible to set a face to the XY-plane to a face of construct plane when exporting as STL?
Usually it is simple to rotate the STL files in the slicer but it would be so much better to be able to set the XY-plane before exporting, especially in cases like this with unknown angles.
Thank you in advance.
Eric
