Default move behavior
KirillChepizhko
KirillChepizhko
What in the world is going on...  the default parameter in the Move tool for move object used to be body, not face ( in parametric modeling mode). Default with history mode on should be body, default with history mode off should be face. The very least you can do is remember last chosen option or let us pick default. This is frustrating as hell. f0db2d3c18bf9c7d2ab90ec50536c6b4.png
You cant freely move faces in parametric modeling, why the hell is it a default !!
michallach81
Really?
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
KirillChepizhko
Im guessing the ability to move faces in history mode came with the latest update as well as it wasnt the case earlier. Doesnt change my point - why do i need to adjust the setting everytime i need to move a body ? Is there somthing that i am missing ?
michallach81
Nope, UI default behavior is an arbitrary decision.
Michał Lach
Designer
co-author
xander.luciano
Hello!
I'm not seeing this behavior on my end. My move tool remembers my selection choice.
Let me know if you have any questions,
-Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Mike.Grau
Hi @KirillChepizhko,
Thank you for asking about that.
It is pretty much what you select for a feature operation as you can see in the Screencast here:
You can set the selection of "Bodies" by default when you change the "Selection Priorty" to "Bodies" under "Selection"
I hope this helps. Please, keep us updated.
