Body Split bug?
Body Split bug?
macmanpb
Body Split bug?
macmanpb
Try to split that body with the provided plane. 😉
http://a360.co/2lAdmWY
Beyondforce
Hi @macmanpb,
This is not a bug, it's just a limitation:
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Gript.app
| YouTube
michallach81
After your split, would you have two bodies? Check extend if using surface, or use plane:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
macmanpb
Thank you @Beyondforce,
i dont see the woods because about the trees 🙂
You are absolutely right, the splitting tool can only work if after the split you would have two bodies.
You have questioned, what piece that is. This is a welded steel rectangular pipe frame. The splitting is to create each single angled pipe part for that.
Beyondforce
I'm happy I could help 🙂
Btw, you are not the first one, who had an issue with this! I'm sure there is a good explanation to why they limited this functionality. But luckily the solution is very easy.
Ben.
Ben Korez
Gript.app
| YouTube
michallach81
That's not a limitation it's a reasonable consequence of what bodies are, to make it work better we should be able to pick more cutting tools at the same time. For now:
Michał Lach
Designer
co-author
