- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
What in the world is going on... the default parameter in the Move tool for move object used to be body, not face ( in parametric modeling mode). Default with history mode on should be body, default with history mode off should be face. The very least you can do is remember last chosen option or let us pick default. This is frustrating as hell.
You cant freely move faces in parametric modeling, why the hell is it a default !!
Kudo button - If it resolves your issue, press Accept as Solution!
